tikicarver
I ordered some new bulkheads from Van's to rebuild my tail section.
The F411 bulkhead is two pieces riveted together.
As you can see in the photo, they don't fit very well together because of the bends on the flanges at the ends. The center of each is pretty flat, so I'm afraid that if I start using a fluting pliers on the flanges that will put a curve into the center section of the bulkheads.
So how do you rivet these things together and keep the hole thing straight?
![](/proxy.php?image=http%3A%2F%2Fimg16.imageshack.us%2Fimg16%2F3744%2Ff411.th.jpg&hash=2002cddaff530a0570f5e8dd2edb6109)
