CharlieWaffles
So I just finished setting up the trailing edge of the rudder with ProSeal and am now waiting for it to cure. I'm wondering what (if any) miracle product is going to help clean up the holes and the clecos themselves once I remove them. I've read about people "soaking them" but can't a reference to what is being used to try to remove some of the proseal. Also, what attempt should be made to remove any residue from the surface of the skins as well? I wiped them down on both sides before it set, but I'm imaging there will be something somewhere that will need some post-cure clean up.
