Hi All
Wondering if anyone has a safe technique for charging the ODYSSEY battery that is attached to the firewall without removing it.
My battery is attached to the firewall per the VANS plans on the upper RIGHT side. It is a PITA to remove the battery. I have been hesitant to charge the battery while it is still in place because the charging cable would be so close to the firewall and other metal structures that could cause a short if the cable got loose and touched a surrounding structure. Have thought about wrapping the metal end of the charging cable that attaches to the (+) pole with electrical tape to insulate it but it could still be a disaster if it got loose and contacted a metal structure.
Would welcome any suggestions.
