Nothing to it. I'm not a welder so out of practical necessity, I cut the HF engine stand in two and then bolted angle iron onto it. I sized it so the landing gear would clear the floor. The extentions on the "spider" that reach the four corners of the firewall use the same angle stock. It took less than 2 hours to fab up the whole thing up. It was bolted together using AN4 bolts. In practice, I could easily rotate and lock the fuselage into any preferred angle. Doing so, I just had to make certain I did not accidentally "walk" the tailcone off its padded sawhorse!anyone have details of how to build fuselage rotisserie for quick build rv8 on way to harbor freight for engine stand..what about tail
Standard build ends up the same. Do not final size drill until you get the engine mount and use it per plans. I drilled from firewall aft matching hole locations of mount only using an3 or 4. Once I removed rotisserie and final drilled with engine mount, it lined up perfect. One item I feared but worked out probably better than most tasks. The rotisserie is totally worth the effort.Sorry to bump an old thread, but this has a lot of great info, so I think it's worth it. My question is - the holes shown above being used make sense - but there is material behind them on my QB fuse. They would need to be drilled to clear them for use on the rotisserie. Should I drill the four holes in the corners?
It would be pretty easy to drill from inside the fuselage out or the other way - I would assume that these holes should line up with holes in WD-802 and WD-803 on the other side. It's just troubling to me that my QB fuse has stuff behind them... so I wanted to ask since I don't have any drawings or anything yet for the engine mount to ensure it's correct to drill these holes. I can't find any specific reference to these holes, though I'm pretty sure it's where the engine mount attaches once I'm to that point.
View attachment 65878View attachment 65879
Whatever the design, make absolutely sure the forward and aft cradles cannot possibly spread apart or teeter/totter. Talk about a bad day. No it didn't happen, but I saw it possible.Got it! Thank you for the confirmation. I'll use smaller AN3 bolts just to give extra space to upsize for the final holes when the engine mount is ready to go on.
I have the same exact Harbor Freight engine stand. Did you do anything to put it at a 90degree level with the ground? Or is it close enough? I don’t see anything in the photos that would level it?Here's some pictures of my rotisserie made from a HF engine stand and two flat steel bars. Attached them to the engine mount holes with I believe AN4 bolts. Tail stinger on a padded sawhorse made it the perfect height to rotate.View attachment 65936View attachment 65937
A padded sawhorse worked for me. If I needed to rotate it I'd just slide the sawhorse aft and rotate on the tail spring steel gear. Mine was a slow build fuselage but the pictures you see are at about the QB stage. The fuselage is relatively light at this stage so you can easily adjust the tail for different heights. Perfect example is when the LG gets aligned.I have the same exact Harbor Freight engine stand. Did you do anything to put it at a 90degree level with the ground? Or is it close enough? I don’t see anything in the photos that would level it?
