IowaRV9Dreamer
I'm working on the aluminum lines between the fuel pumps, Andair fuel selector, AFP filter and AFP boost pump. To say that it is "tight" in that area is a bit of an understatement.
The body of the AFP pump is uncomfortably close to the line between the right tank and the fuel selector. Under 1/4" spacing, if that.
I was thinking I could use a spiral wrap around any of the fuel lines that were close to anything else, as a protection against abrasion.
This is what I was thinking of: http://www.steinair.com/storedetail.cfm?productid=392
The other thing I though of was some Home Depot plastic tubing, slit lengthwise.
Anyone have any better ideas?
