ERushing
Good Morning,
I started trying to mount my steps this morning and couldn't the step to fit into the step mounting bracket without pounding on it. That just didn't seem right to me.
Before I go lightly sanding the inside of the step mounting bracket, I thought I'd check in here and get some advice. What was your experience with the step/ step mounting bracket?
Should the skin around the step mounting bracket/ step being sanding back a bit too? I noticed some puckering in the skin when I was trying to insert the step. Does the weld go inside the skin or sit outside?
Also note that this is a quick build fuselage. The skin hole is a pretty tight fit around the step when I try to insert it.
Thank you!
Thank you!
