ChiefPilot
...do I get the pitot/aoa lines into the fuselage on my -6A project? I have two 1/4" soft aluminum lines from the Dynon pitot/AOA tube, and I have them run to the wing root plus about 6" or so each. I'm not sure what the best way to get these lines inside is : AN fittings or a hole-with-a-grommet-in-it.
Also, since I have electric elevator trim, the hole through the spar where the manual trim cable would go is appealing for running wires through the cockpit, however, if/when I pull the wings off I'd need to cut the wires. Is filing this hole out to the end of the spar an ok thing to do? It seems I heard/read about these somewhere, but can't find the reference.
Thanks!
Thanks!
