AAflyer
So, I'm trying to get my wiring in shape by, first, determining where I need to clamp and/or zip-tie. one of my questions is; why is it "OK" for a bunch of wires to bounce around in a conduit, but its NOT OK for that same wire bundle to rattle in a snap-bushing in a bulkhead. It seems, that as long as I've got that bundle secured in such a way that it can't be pulled back and forth across the snap bushing, then it should be OK to dispense with the often adopted "bracket and adel clamp" procedure…especially if the bundle has another layer of protection, like spiral wrap or short rubber sleeve.
Specifically, the bundles going through my main spar box…multiple holes, each with snap bushings…do I REALLY need to install a clamp on both sides of my spar at all these holes?? I really HATE drilling into my spar.
Can some of you DAR's tell me what would pass YOUR inspections…?
