Denny Myrick
Member
I'm to the point where I'm riveting the Baggage Ribs to the Center Section Aft Bulkhead with the LP4-3 rivets. Step 4, Page 21-02, last sentence reads: Install all the rivets so that the manufactured heads are on the bulkhead. I assume this means don't rivet from the baggage rib flange side, which is far easier than from the bulkhead side. The pneumatic rivet gun won't work because there's not enough space between the bulkhead. That leaves the only other option of using the close-quarters Avery hand pop riveter from the bulkhead side. There's hardly enough room to do this either. Anyone have any suggestions to make this easier? Why can't I rivet from the baggage rib flange side which would place the manufactured head on the side opposite the bulkhead?
Denny Myrick
Denny Myrick
