spaceflightmeow
Active Member
I got the 3/16" Harbor Freight pop riveter. I installed the 1/8" nosepiece and test pulled a couple of 1/8" rivets (just in the gun, not installed in a hole). It took two pulls to cut the stem off the rivet both times, so I think it needs oil per the directions.
How much hydraulic oil do I add? Fill up just the the tube in the center? (red arrow) Go a little more and cover the black ring? (blue arrow) Fill the whole base up? (would be more than 1 cup of oil so I highly doubt it)
![](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FJCX04dq.jpg&hash=16df0922372d9224d3f1d99cab1742a1)
This question seems to be asked all over the internet but I can't find a clear answer.
Thanks.
Thanks.
