drone_pilot
![image.jpg2_zps6al6si8c.jpg.html](/proxy.php?image=http%3A%2F%2Fs280.photobucket.com%2Fuser%2Fbshaw4%2Fmedia%2Fimage.jpg2_zps6al6si8c.jpg.html%3Fo%3D0&hash=540ab7b083a60a08d8772b28fe9da5a9)
In order to get vents level and a consistent gap on nose ring, I had to move the bottom cowl about 1/8" forward. This created an "underbite" on the outboard cowl inlets at the horizontal seam. I'm totally new to fiberglass but I have been reading a lot in these forums. Is it acceptable to build up the top cowl inlet with micro and sand to match the bottom cowl or would I need to use something more structural here? Also, how do I need to prepare the surface, etc?
