LettersFromFlyoverCountry
When you first get your firewall, you're told to add doubler plate for a fuel pump. This assumes, however, that you're going to put a carbureted engine on the beast. But I decided, later, I'd have fuel injection. The little fuel pump isn't needed because a high pressure pump is installed upstream. But there you are with a doubler plate and two nutplates.
This weekend I located and drilled the holes for the doubler for the fuel line pass-through, moving it about 3/4 inboard because the plans call for part of it to be riveted to an angle that the starter contactor already has a nutplate mounted on.
This did not cause a problem until I realized that the distance between the doubler for the fuel line, and the doubler for the fuel pump I'm not using, leaves me no room to drill a hole for the throttle cable. (You can see on the fuel pump doubler that I "scalloped" out room for a hole for the throttle cable, but the hole for the spiffy SafeAir "eyeballs" needs to be 3/4" and there's a one inch nut that holds it in place. That isn't going to work here.
I could move the throttle cable hole further to the center, but now it'd be in danger of hitting the engine mount and I just saw images on Van's Air Force this week of what can happen over time doing that.
What I could do is slice an angle off the bottom of the fuel line doubler, ignore one of the rivet holes I've already drilled, and drill another.
The other option is just to locate the pass-through for the throttle cable through the doubler that was originally installed for the fuel pump.
But I'm not sure how much leeway I have in moving the location of this hole all over creation.
Larger images available on the blog.
![fl_passthru_1.jpg](/proxy.php?image=http%3A%2F%2F4.bp.blogspot.com%2F_nw6qmkwwuYE%2FS3cm7L6Km-I%2FAAAAAAAACfo%2FiDAonwZIVPs%2Fs400%2Ffl_passthru_1.jpg&hash=d9c48e8e59d4b45a3a09111fe4447248)
