How much is trimmed off hs stab tips???
Paul 5r4
Hi Friends,
I'm completing the tail section of my 7A and have reached the point of trimming where the counterbalance arm passes aft of the fiberglass stab tips. Using the 13/16, (max 7/8), dimensions on the plans for the rod end bearing on the elevators.... I'm finding when I try to put the elevators on the HS stab, I'm going to have to cut about a FULL INCH off the aft face of the fiberglass tip and the very tip of the 601PP skin. Is this typical or have I messed up someplace. Seems like a lot to me. The VS stab and rudder fit at the top only required maybe 1/4 inch at most. Just don't want to start hacking away and mess up. Your help is appreciated.
Paul Gray
Foley, Alabama
RV7A Tail section completed.... Almost.
I had the same question, just trim it so it travels without hitting. I gave myself the same gap as there is on the side.
