claycookiemonster
Rather than mix several small batches to seal tank access plates, and then baffles, I'm thinking of simply mixing up the entire pint batch they sent me. They probably measured it better than I'll do, and then I'll just divide it into smaller batches and freeze them. I've got some of those huge horse syringes. The question is, will an entire pint kit fit into the larger metal can once I add the white portion?
