My 6AQB came with, free of charge, a twist in the midportion of the fuselage which lowers the rear spar stub on the left side enough that setting the incidence per Vans, is impossible; it violates the 5/8" rule.
After exhaustive measurements by multiple means and having several builders look at it, the best we can do is to compromise and increase(lower the rear spar) on both sides until the incidence is an additional .2 degrees(total of 1.2 positive?). There will be no room for error whatsoever on drilling the holes at this setting.
If my ciphering is correct this is over a quarter inch on the wing and will raise(?) the tail in flight four or five times that. I am under the impression that the front of the horiz. stab will have to be raised .2 degrees as well to mitigate the change.
Is this much change a big deal?
What happens to the flight characteristics in this kind of setup? Speed, handling, propensity to and recovery from spins, etc. a problem? Everything else appears to be dead on: sweep, squareness, dihedral etc.
Dave A.
6AQB
Dave A.
6AQB
