If got a 6A and had pulled the tanks to proseal the sender units. It previously was just cork. .... And weeping.
I've got the Princeton capacitance probes with 2 set points. Fuel reads out on the GRT EIS I've always ignored the level readings because they were off. I just use the fuel totalizer.
I figure now is a good time to recalibrate the senders and the EIS totals.
Question: does anyone know what amount the tank will hold which will give a full reading? I was going to reset the totals so when the level got down to the probes they would actually read in a linear fashion.
