Since we are on this subject, I also am switching from Fixed to C/S, should I be C/G concerned ? Is it possible that I will need to move battery from firewall to rear ?
RV-8
I find it odd that Hartzell will post all the specs on the full line of props but only a few have the weight listed. I would think this is a pretty important number not to be left out of the specs. I've searched lots of Hartzell catalogs and found very little weight data. I guess a call or email to Hartzell would get you the data you need.
The data you want is published in the Type Certificate Data Sheet and can be looked up on the FAA TCDS website.
On my second 8 I switched from a Hartzell CS to the much lighter composite CS. Made a big positive difference.Since we are on this subject, I also am switching from Fixed to C/S, should I be C/G concerned ? Is it possible that I will need to move battery from firewall to rear ?
RV-8
