Speed
GENERAL PHILOSOPHY:
I personally don't stress a lot about the last knot. Some weight savings are cheap and easy. You can keep weight down with a lighter paint job, lighter pilot, less interior decoration and less equipment. You can easily reduce drag by properly sealing your flaps and canopy. Before spending too much time and money, remember that many speed mods won't have a measurable gain. Here is an example:
Should I pay $200 for a titanium widget that?s 1 pound lighter than the stock one? I typically fly my RV-10 around 2,300 pounds and climb at about 1,500 fpm. This widget would reduce weight by (1/2300 lb) x 100 = 0.043%. The rate of climb would be increased by the same percent, 1,500 fpm x 0.00043 = 0.645 fpm. I probably couldn't detect or measure the benefit of my widget... but if I use the money to upgrade my headset, I'll probably notice and enjoy it on every flight!
RACING PHILOSOPHY:
If you race competitively, you can probably justify a greater investment in performance.
A DIFFERENT KIND OF SPEED MOD:
I use my airplane for travel so I?m mostly concerned about my door-to-door trip speed. NASA found that trip speed is extremely vulnerable to ?inter-modal delays? and prefers strategies that address delays over the traditional approach of increasing cruise speed.
I carry a 250cc motorcycle beneath my RV-10 and save lot?s of time:
1)Reduced trip planning? no need to find or reserve ground transportation.
2)Reduced inter-modal delay? hit the roads in 3 minutes instead of 21.5 min (national avg.) to rent a car.
3)Shorter Drive? only 1/3 of airports have ground transportation services so I can often land closer to my final destination.
My motorcycle frequently allows me to reach my final destination 20-60 minutes sooner. On a 200 nm trip, I would need to fly 56 to 583 knots faster to save those 20-60 minutes through conventional speed mods! My neighbor flies a much faster SR-22 but I almost always beat him to the final destination
