How long is the nipple on a CH 48110-1 / AA48110-2 oil filter?
noahhl
Active Member
Anyone happen to know how long the 3/4-16 nipple on a Champion CH 48110-1 or Tempest AA48110-2 oil filter is? I can find overall dimensions of the oil filter can, but I cannot for the life of me find the length of the nipple itself.
Trying to figure out if I have enough clearance to get the oil filter off if I use a flat plate instead of a recess on the firewall. I don't want to actually take the oil filter off since the engine is still full of preservative oil.
I'll order another filter so I can measure, but figured it was worth a shot in case someone happened to know that dimension (or how little clearance you can get away with and still get the oil filter on/off).
Thanks!
Noah
Allow 5/8" for a Tempest nipple. I had to go measure it.
I used to be able to tell by just rolling one between my fingers.....:D
I got one of those from you :)
For anyone else thinking about it, Dan's bubble recesses are absolutely beautiful. I might still use it -- it just seemed when I test fit it on there with the engine that I might be able to get away with a totally flat plate and it would be just a little bit easier to insulate the firewall and attach penetrations.
...I might be able to get away with a totally flat plate and it would be just a little bit easier to insulate the firewall and attach penetrations.
True enough.
FWIW, I blew several because I'm nesting them in a current project, with 0.060" insulation sandwiched between.
