Thanks, guys. I'm actually going the other way. Rather than holding the tail up, I'm building something to hold it down. My friend with the PropJet has a cut-off steel drum on casters that is filled with cement and has a chain on a short post that connects to his tail tie-down plus lugs on either side to secure a strap over the tail as a backup. He uses it to keep the aircraft in level attitude when he jacks the plane up to do a gear retraction test. Granted, I don't have retractable gear but I like the idea of a portable tie-down and it can double as a stand by replacing the chain with a pad. I think I can also use it up front to keep the plane level until I have an engine on the mount. Now that I have N14MX on its gear I have verified the tail height; sawhorses are doing the duty right now but I don't want to be working in the fuselage and find that I've caused a sawhorse to dent the bottom of the tailcone, even with padding.
