One for the oldies. I have early 12 with the visual fuel window. I later added the fuel gauge. When the gauge says full (bouncing off the top) the tank is still not full. Possibly one for Scott. Where should it show in the window with a totally full tank?
The design philosophy of the different fuel level indicators (fuel gauge on the EFIS, Site window on the side, or the mechanical float gauge )on the RV 12 is to show you how much below full the fuel level is in the tank.
It is not to tell you when the tank is full, because you should know that just by the act of filling it.
Because of variabilities in the adjustment of float arms on the electrical, senders or manufacturing variabilities in the mechanical float gauge, both require some personally done calibration. For the.EFIS gauge, this is easily done by adding measured amounts of fuel during the calibration process. The same thing could be done for the mechanical float gauge if you wanted more accuracy. Just be aware that there is a difference in indicated fuel level whether the airplane is on the ground or in flight. And as you already indicated, the tank holds more fuel than can be actually measured by the mechanical gauge, since the gauge isn’t mounted at the highest point in the tank.(the far after portion). If I remember correctly, I think the difference is only about 1.8 gallons.
The Moler gauge shows full when you have about 16 gallons in the tank, not sure about the visual tank window as I replaced it with an aluminum panel when I build the tank. The tank holds 19.8 gallons, however the gauge(s) max out at 16 gallons (PAP section G8 only calibrates the fuel to 16 gallons). If your tank window is not marked from the PAP calibration procedure, you may want to recalibrate to match up the float gauge, Moler gauge, and tank window levels.
