I've done a fairly extensive search for HOW did you all make your RV-12 canopy frame fit! I've looked at maybe 50 posts by builders who have already completed their 12s. Those who say that they have had to make it fit don't say how. I did get some advice from my friend in the Switzerland - thank you sir.
My plans instructions don't say how to bend the canopy pieces in order to make it fit. I may just try to bend the frame and I don't like the results, then find a welder and have the frame welded 'to fit' my airframe. Send the welder's bill to Van's?
My canopy fit is great (parallel to the longeron) on both sides from the forward pivot hardware (going rearward) until the weld where the frame material is cut and welded. The welded angle on both sides of mine leaves the canopy frame 1/4" higher than it should be at the back of the frame where the rear bow is welded on.
Can I bend the canopy frame near enough to the weld to make it fit? Should I just bite the bullet and have a welder cut and re-weld these joints an Van's recommends? Should I just forget it and build on?
The rear 'bow' is angled correctly at this point but if I bend or have the sides re-welded, then I'll have to bend the bow or re-work the welds at base of the bow as well.
I'm not building a show plane but really want to make my 12 pieces 'fit' as well as possible. Parts that don't fit bug me - and I'll be looking at the inside of my 12 canopy a lot when I get it flying. (Kind of like a door in a house that wasn't hung right)(which I replaced).
Any suggestions specific to how to bend the sides of the canopy frame is appreciated. Or just find a good welder? Replies appreciated.
