Hi -
I made a big mistake and riveted the hinges on my flaps in place before aligning my flaps with my ailerons. It turns out, though, they're pretty close - the flap would need to come out about 1/16" to make it perfect with the aileron in a neutral position.
I think this is purely cosmetic, and I feel like it meets the 5-foot rule for cosmetic things. Is this trailing edge alignment actually cosmetic or is there a safety issue or control issue as well? Would you remove and replace the hinge if this were your build?
