danielabernath
The issue is this: I took over the cover plate on belly of plane beneath fuel tank and I see this. The dark one is BLUE.
1. I disconnect this, using two opposing wrenches
2. I work gingerly as this is a tight spot,
3. I take out fuel filter
4. I remove the introduced substance which the filter has captured.
Any tips if you have done this before?
