Kobwo
Active Member
Hello,
I was wondering if this air compressor will get the job done ok? It's a Kobalt, brand new in the box for 1/2 price. I don't have 220 in the garage so looking for a 110v that will work.
Cheers
Kobwo
30-Gallon Cast Iron Oil Lubricated Air Compressor
Cast iron, V-twin cylinder, oil lubricated pump features: one-piece cast iron crankcase, thermally stable cast iron cylinder body, aluminum head and machined cast iron valve plate, automotive style ball bearings, and durable stainless steel reed valve. Heavy duty induction motor for maximum performance and efficiency Fully assembled 30 gallon ASME tank with pre-attached pneumatic wheels, quick-set regulator, tank and working pressure gauges, quick connect air outlet and on/off switch for ease of use
155 PSI max pressure, 6.2 SCFM @ 40 PSI, 5.3 SCFM @ 90 PSI, 1.6 running HP
Cheers
Kobwo
![846212001646lg.jpg](/proxy.php?image=http%3A%2F%2Fimages.lowes.com%2Fproduct%2Fconverted%2F846212%2F846212001646lg.jpg&hash=e597c7847816a625d31641cdd9341c83)
