Lan Vinh Do
Hi. I have a hot tunnel. I bought the airplane in november. Didn't fly much during the winter. The builder installed a fan to vent the tunnel but since it wasn't working, i just removed it ( he said that he didn't had a hot tunnel with the fan)
I made a cross country last week end and the tunnel was really hot. It was hotter when i was using the heat. My concern is that when all heat wws turn off, there was still a small draft of really hot air that was comming to the rear heat hoses. The exit hole was burning hot to the touch. So it's probably the hot air of the other heat box that enter the opposite hot air box. I will do all the fix that are suggest on previous post and i already put a new fan to vent the tunnel but didn't had the chance to fly with it yet.
My concern with this setting is that if my carbon monoxyde detector go on, my only way to stop the leak would be to turn off the engine since if i just close the heat, it will still come inside the cabin.
Maby not a concern now with all our relatively new engine and exhaust muff but in 10yrs!!
Lan Vinh Do
Lan Vinh Do
