Golf Echo
Active Member
So, today I match-drilled the HS-609PP reinforcement bars to the HS-603PP rear spar channels. Today, I also made my first bone-headed move on the build.
I match-drilled the elevator hinge brackets, and enlarged the HS-411 attach holes to #12. Then, I disassembled. That's when I realized that I had clecoed the top HS-609PP at the bottom of the spar, and the bottom HS-609PP at the top of the spar .
The issue being that the top inside edge of the top HS-609PP (and the bottom inside edge of the bottom HS-609PP) had been been given a larger radius to fit nicely into the radius of the spar, as per the instructions.
I think I have 3 options:
I think option 1 is my best bet, but I'm not sure if I should be at all concerned with removing more material from another edge of each HS-609PP to get a nice fit. It's not a lot of material, but I figured I'd at least throw it out there before I build on.
What says the VAF Brain Trust?
- Radius the other edge to fit nicely with the spar radius - I think this is my best option
- Put [what was originally] the top HS-609PP back at the top (where it wasn't match-drilled to) and hope for the best at assembly time - I'm not a big fan of this idea
- Order new HS-609PP and HS-603PP parts - I really hope this won't be necessary...
