I have an 8 that I didn't build so I don't have the plans. When the Horizontal Stabilizer is installed is it installed level?
thanks
Just a suggestion, more than an answer to your question... it would probably be worth your while to purchase a set of plans if possible. (I'm surprised that they didn't come with the plane.) Whether you choose to work on the plane yourself or have a general A&P work on it, they would come in handy and are probably especially important for the non-RV builder to have.I have an 8 that I didn't build so I don't have the plans. When the Horizontal Stabilizer is installed is it installed level?
thanks
I checked the tail yesterday and the horizontal is 2 degress difference from tip to tip.
My construction manual is dated 1998. The pages might be missing. If any of you guys have a scanner you could scan the pages and email them to me I would appreciate it.
thanks,
This all started with a rolling problem I have with the airplane. It would roll one way at slow speed and the opposite at high. I have fixed the low speed problem, with the ailerons. I have checked wing twist, wing angle, sweep and on and on. I checked the tail yesterday and the horizontal is 2 degress difference from tip to tip. I figure this might be my problem or at least hope it is.
