lucaperazzolli
Hi,
I do the eight holes! After a lot of measurements, a lot of smart level check, perfectly squared check THEN I do it. Wow, what a thrill !
After drilled everythings undersize I worked on a my table for perfect square drilling, so I mounted my HS and ....... damn, the incidence angle with my 1/16 spacer on the top of the rear HS longeron was 0.1 degree. I really don't know why.
What do you think that I must do :
1) keep on build
2) add a washer over the 1/8 spacer underneath the HB front spar and try to level again
3) other suggestS ?
Thank you !
1) keep on build
3) other suggestS ?
Thank you !
