Hi all,
I?m building the couple of brackets related to the Horizontal Stabilizer, starting from aluminium AA6 187x2x2-1/2 as reported in the RV-10 8-3 plan.
The result of the work I did is satisfactory, but the issue is in the original aluminium bar.
I?m a little bit concerned that the original AA6 aluminium bar is not ortogonal; the faces that should keep an angle of 90 deg are affected by an error grater than 5 deg.
Are there anybody with similar experience?
Because the brackets hold the Horizontal stabilizer, this gap could create some out of control strenght.
Thanks a lot
Francesco
Thanks a lot
Francesco
