MartySantic
On Page 09-02 the plans require quite a bit of countersinking. Figure 1 shows two machine countersinks in each HS-1211 spar cap for two CS4-4 rivets BUT there is no corresponding step in the plans that tells you to countersink these holes. Also, I believe, the plans should tell you to countersink for the CS4-4 rivets using the "special" 120 degree countersink as the CS4-4 rivet has a 120 degree head. CS4-4 rivets are also used on the HS-1202 spar and HS-1203 spar.
Also suggest reading ahead and countersinking all of the 3/32" rivet holes in each of the components and then changing/setting the countersink cage for the 120 degree CS4-4 holes. It takes me a while to set the cage for the different countersinks. Bet some of you have more than 1 cage!!
Anyone know if a 120 degree dimple die set is required anywhere in the tailcone or fuselage plans?? Also, let me know if the above is in error.
