Yes, those rivets were charming little buggers. I managed to set them using a small bucking bar from Avery, #615. (see photo at
https://www.averytools.com/cart/p-27-bucking-bar.aspx).
First, I covered the bar completely in duct tape except for the small bucking surface on the bar?s left side, facing the camera in the photo. The bucking surface is about 0.3? x 2.0?. Next, I lowered the bar into the HS so that its long edge rested on the inside of the leading edge of the skin, and the small bucking surface was positioned on the bottom rivet. It was necessary to remove the cleco from the 2nd hole to prevent interference. Then I reached WAY down and managed to get a finger grip on the bar, hold it against the rivet, while holding it away from the skin, and holding the rivet gun with my other hand (set at about 35-40 psi). Also, I use a swivel-headed rubber-shrouded flush rivet set on the gun, which makes it much easier to NOT dent the skin.
I started with the center rib, but had the inboard and outboard nose ribs clecoed in place. I also clecoed in the corresponding main ribs to hold things together while I reached in.
I can?t remember for certain, but I think I also used the rubber tube trick mentioned above in jcoloccia?s post. I use rubber vacuum line tubing, cut to length slightly longer than the protruding rivet. Place the piece of tube on the rivet, then push the bucking bar onto the rivet+tube, and the tube presses the rib tightly into the skin.
Not easy, but it can be done. Good Luck!!
John
