horizontal stab bolts
danweseman
Active Member
Hi Guys dose anyone know, or has anyone seen a RV-4 horizontal stab bolted on with AN4 bolt where the rear spar attaches to the fuse "bars"?
In my parts collection I have a decent horizontal stab that was drilled to another project. the rear bolts are very close to fitting but would need to be up drilled to an4 for proper holes? I guess the next option would be replace the "bars" in the fuse
thanks for any advice Dan
I mis-drilled one of mine and up sized them to AN4. I talked to van before I did it and he said no problems as there is plenty of edge distance.
Edge distance
Hi
Edge distanceis the key here ifyou have enough no problem..... if not then dont do it.
