MarkChristopher
Member
So I am ready to drill the final four holes to secure the horizontal stabilizer angle of incidence and I'm finding a disagreement between the right and left tooling holes. If I get the right side aligned front/back then the left side front hole is 2mm higher than the back hole. Of course if I align the left side, the right side is off 2mm. I have confirmed that the fuse is level and the horizontal stab is level with the fuse but the mis-match concerns me. I can split the difference and make each side off 1mm but before I drill, I want to know if others have had this issue?
As background: I am using a straight rod inserted in the two aft holes and another rod in the two front holes then I measure using digital calipers from the top surface of the rod to the deck on the fuselage. I have confirmed the spacers are in place and I am measuring as close to the holes as possible so as to not induce a bend in the rod.
Thanks!
Thanks!
