I'm filing the reinforcement bars (609PP) and wonder how much grinding/filing is permissable. Every time I turn around I find more scratches that need to be removed.
Van says all scratches need to be removed and finish should be that of a satin finish produced with 400grit wet/dry. I do have a couple of scuffs that will require a fair amount of grinding. Any thoughts you'd care to share? I put a mic on it and They are .187 thickness,
Tony
Tony
