Berchmans
Whenever undertaking a maintenance issue be sure and check the simple things first. By way of example I will talk about a fuel leak on one of my aircraft. Now this leak was on my Citabria on floats but since I also have an RV8 I believe the issue is still valid. One day when heading out to go flying I noticed a drip, drip drip...of fuel come from the back on the cowling. Immediately turned the fuel selector to the off position and went to work on the cowling. Removed cowl, only dropping a couple tools in the water. Started checking all the fuel connections and could find nothing loose. Turned the fuel selector back on a sure enough, drip, drip, drip...coming from the bottom of the carb. Went over it with a fine tooth comb...nothing...went back to fuel selector...at which point I noted that the Primer was not in a locked!...Always start with the simple things first...happy new year.
