Began riveting the leading edge to the left main spar. Discovered that two holes on the outside of the rib flanges do not match the spar holes. They are about 1/2 inch off. Specifically the two problem ribs are the 4th and 5th starting at the outboard rib. I checked the right main spar and found the same problem. I have checked all the ribs for identification and measured the hole distances. The main spar holes for these two ribs in question are not equidistantly spaced. Anyone run in to this or did I miss something. Vans said to just back drill and move on.
