Holding the wing vertical
rv8pilotpaul
Active Member
Anyone have a picture of how they are holding the wings vertical when installing the outboard leading edges and/or fuel tanks?
Ribs Vertical
I didn't hang the wing vertical, I put it on the bench bottom side up, riveted the top, then pulled it over the edge a little, put some weight on the backside and banged the rivets from underneath with someone up top holding the bucking bar. It was fun, but it doesn't take that long. Then I put it in the wing stand.
This is how I did it
1. place a dense foam pad on tabletop
2. prepare some sand bags. I used ziploc bags.
3. place spar, ribs up on pad with LE attach area hanging off table.
4. use sandbags on spar near inboard end to hold spar down.
5. place 2 x 4 across top of inboard spar. clamp lightly to table to insure the wing docent move.
The pad protects the table from the bolts on the bottom of the spar. A couple of clecos on the bottom side of the LE will hold it well enough to go to the topside and secure it.
I put some moving blankets on one of the EAA work tables. Laid the wing on it and hung the outboard end off one side. Supported the overhang with one of these I happened to have from a garage sale. I did put some padding on the roller. Clamped the spar to the other end of the table. installed the leading edge.
I "crafted" :) this. It was cheap, quick and not pretty. Used a few 2x4"s and some shipping crate sides. Used it for both wings without a problem. You can use it like shown or you can put it spar down on either the top or the bottom end.
As others have said, I attached my leading edges and tanks while the wings were horizontal on the build table. There's no need whatsoever to do this in the vertical.
Fuel tanks similar method. Nice height to sit on stool and install screws, remove screws, fit, repeat...
