Rick_A
If you're thinking about installing the G3X touch I've got a couple of hints for you.
1. If you're still working on the Empennage, you will install a new longer static line that goes forward to the baggage bulkhead area. The short line that goes to the ADHAHRS mount area will be removed & replaced.
2. You're going to route 2 more wires back to the Pitch Servo connector (the one under the pilot seat). So keep that in mind while you're doing the fuselage wiring.
3. Don't install the all nut plates on the lower flange of the panel base. There is a doubler that is installed on the lower flange. If you're doing a single screen, all the bottom nutplates that attach Left Panel section are installed after the doubler is installed. If you're thinking about Dual screens, the same applies to the right side. I believe it is 7 nutplates per side.
4. There is an option in the plans to install a nutplate that is used to attach the screw that hold the Adel clamp that goes next to the Left side CPU fan. Don't install the nutplate. The screw hole is enlarged to accept an AN3 bolt that is used on a larger Adel clamp.
