Just finished my second flap this way… I did sort of a minor modification of this… I only used about 5 or 6 426 3-4 inserted into evenly spaced holes after clecoing then squeezed them just a teeny bit so they were snug and held the skin and brace together … removed the clecos, put the flap on, clamped, aligned and drilled…. Simple pimple! Make sure once done you countersink the brace. The hinge rod was a pinch tight for my liking so I took it out. Chucked it in a drill and ran it through some 220 sand paper. Looks great, swings smoothly and is straight as far as I can tell.
