Mike S
Senior Curmudgeon
I just finished the installation of the Higher Power hangar door, and am extremely happy with the quality of the product, the clearness and easy to understand instructions, and the function of the door.
http://www.hpdoors.com/index.asp?active=home
All the parts fit exactly as they were supposed to, all prepunched holes lined up
correctly, all hydraulics and electrical stuff fitted and worked first try.
I am very happy with the product and service I received from Higher Power, and strongly recommend them to anyone considering this door.
Virtually all assembly and installation was done alone, literally only used help with measuring the diagonal lines (thanks Paul) to square the door, and Laura helped with bleeding the hydraulic lines. This is just a huge Erector set
----you can do it.
Here is a video of the door in action------this is the second time it was operated, so Laura is a bit excited..........
https://www.facebook.com/laura.starkey.180/videos/1308153965957531/
