Hello everyone. I have the D180. During a cross country trip I received numerous "high voltage warnings". When I looked, the D180 was showing 14.7 volts. The warning would last only a few seconds and then the volts would drop down to 14.3 or so and then peak again after several minutes. The temperature was 99f when I left and I'm wondering if high temps can effect the voltage regulator's ablity to regulate the voltage? I flew today and was seeing 14.1 - 14.4 volts most of the time and never received a high voltage warning. I'm not sure what the "volts" mean. Is this what the battery is charged to or is it what the voltage regulator is out-putting to the battery?
Any ideas or thoughts?
Thanks, Rick.
Thanks, Rick.
