I checked the archives on this and found that most of the threads drift off topic and become argumentative. Here is the problem: On my buddies plane we both built, at the condition inspection last month among the usual, we swapped out the BM EFIS for a Dynon Skyview. Afterwards, the oil pressure was reading 138 psi at run-up. After contacting Dynon, it was suggested the problem may be the oil pressure sensor used for the BM may not be compatible with the Dynon. A new sensor was ordered and installed and we get the same high readings. Pressure readings were verified with a simple analog gauge. The engine is a Superior IO-360 with C/S prop. Superior suggested a possible adjustment is needed in the relief valve. No change when adjusting the pressure screw. They then suggested we remove the pressure relief valve assembly and look for damage or obstruction and run a soft wire down the port hole. Everything seemed good. Reassembled and still reading up to 138 psi. Now we are thinking maybe we got a bad filter and that is causing the high readings since it was changed at the condition inspection and that's when the problem showed up. Any suggestions from the engine guru's out there? We are at our witt's end on this and are awaiting delivery of a new oil filter and case of oil.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
