Noticed that after cold start, then taxiing to the fuel pumps, shut down, leave mixture at ICO, when I go to re-start, the fuel pressure is around 80psi. Seems a bit high, but drops to normal (about 25 psi) as soon as mixture is pushed in. Just wondering if this is is ok, since I always leave mixture at ICO after shutdown or should I release the pressure?
