Walt Shipley
Active Member
During taxi tests, with engine rpm at approximately 3,000, I frequently get the "High Fuel Pressure" warning. When this happens the pressure hits the redline of, I believe, 5.8 psi. Normally, my pressures run in the yellow at
around 5.5 psi.
I've read several posts by others who have the same problem and have elected to solve it by installing a Kavlico sensor. But, I really don't want to
spend the money and time on a new sensor. I'l like to get the old one to work properly, I wonder if there is a way to set the redline a tad higher - say
6.0 psi or so. Of course, I don't want to do something that would damage the
engine.
If I DO decide to get the Kavlico, how much do they cost?
Walt Shipley
around 5.5 psi.
engine.
Walt Shipley
