Ditto
I too have had the same problem twice now. In fact, things can be normal for several hours and then suddenly, readings become erratic. Given how erratic they are and the fact that all other engine indications were normal, it was clear that the EGT was not accurate. In fact, mine sometimes fluctated to a negative value! My spade connectors were crimped using a very high quality crimping tool but I still discovered that it appeared to be a issue at the crimp (after replacing a probe, only to find it was probably ok). I have found it is critical to very carefully strip the insulation on these wires, making sure that the non-metallic strands (the ones that look to be silk) are carefully cut away. Then mark the wire to make certain that the insertion in the spade is absolutely correct during crimping
Jeff
