Bryan Wood
My plane has recently started indicating about 11 knots high in cruise and also at stall. Reaching under the panel confirms the fittings from the static ports to be tight on the airspeed, altimeter, and VSI. Tomorrow morning the baggage bulkhead is coming off to see if the lines came loose at the static ports. Have any of you had similar indications on your airspeed indicator and if so what did you find to be the problem. Hopefully the airspeed indicator didn't go south on me.
