OK, we have seen the panel mockup now. Here are all my very specific Skyview questions!
I have all kits in hand except avionics. I even have the autopilot servos installed (marked "Skyview Ready."). Vans will send you those now, without the $400 AP-74 faceplate, which is not used with the Skyview. My fuselage is complete and I have been running wiring.Have not done canopy, fuel tank, or engine yet.
These questions are from the point of view of building the plane now and expecting to soon order a fully optioned dual-screen Skyview system.
1. Do I go ahead and connect the extra two wires on the ap servos which the plans list as "future" but for which you put on the male-female connectors anyway? If so, do you disconnect any of the others? I ask because they can be hard to disconnect with your hands in a tight spot.
2. I assume the skyview will be bought with its combination antenna-GPS receiver. Correct?
3. I assume this skyview gps antenna/receiver will mount on the antenna tray I have already installed, maybe with some mods to that tray. Correct?
4. I assume that with the skyview gps antenna/receiver installed, there will still be room on the antenna tray for a garmin gps/xm antenna as well. Because I WILL install a Garmin Aera in order to get the XM weather. I figure the Dynon capability for this may lag for a considerable while. I don't mind shelling out for the Aera.
5. I assume the skyview will include the dynon transponder which will mount somewhere behind the panel.
6. I assume that all 3 of the existing control panel aluminum pieces (the ones with instrument cutouts) will be replaced with different ones for the skyview option(s). So I have not bothered with trimming those out. Similarly, the differences might also mean replacement of those two radio stack angles that fit bewhind the panel - so I haven't bothered with those either.
7. I am wondering if there will be more freedom for mounting a Garmin Aera in a way to make it easily removable - to use some aftermarket mount, for example.
8. I am wondering if the skyview will display xm weather data on its screen, if supplied by the separate garmin. I doubt it, at this time. When they develop their own xm weather product, they might make it possible to use a garmin source -or they might not... Would be good to know.
9. I am wondering if the wiring that connected the garmin gps to the Dynon 180 will also work for the skyview, or if adapter cables will need to be built to go from the existing harnesses to the skyview for that or other reasons. (Like feeding the gps-to-elt wire from the skyview)
10.I am wondering (read a rumor) that skyview installation involves one additional wire back to the remote compass. Would SURE like to know now!!! What gauge wire, if true? One wire or more than one?
11. Obviously the garmin com radio is too far in the future to worry about now, and the Van's panel mockup still shows the garmin com radio.
Does anyone have additional questions not covered? More importantly, does anyone have answers? Maybe someone that has already done integration with a skyview or read/understood all their manuals?
Bill H.
Bill H.
