okay,,, maybe its me (it usually is),, but heres the dilema. I'm making the F-864E cable anchor for the throttle assembly.
using the dims on the plan I need to drill 3 holes that are 7/16 in diameter,, not a problem, however, if I use the dims on the plans to center the drill, each hole will actually cut a notch out of the plate,,, not what it looks like in the picture.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
what am I doing wrong?
Mike
Mike
