I am starting the wings on a partially built RV-8 kit. One wing is partially skinned and the other has just a little work on the spar done. My issue is the previous builder (there are two previous builders on this wing kit) did not flute the ribs. Notice the curved ribs. Does anyone see any problems if I remove the skins and flute the ribs while still attached to the front and rear spar? I've had plenty of practice removing flush head rivets after completing the empennage. Hard to understand why these ribs were not prepped because the leading edge was done flawlessly. I have started the other wing and I inspect and repair the partially completed wing as I follow Vans instructions. Any suggestions?
